Door speaker Question
Old May 28, 2025 | 07:37 PM
Wolfen1086's Avatar
Wolfen1086
Default Door speaker Question
mine is a 96 V10 ram 2500, and I have a blown speaker that is making me crazy, and believe me that's not a very long drive,
can somebody please tell me what size speakers are in the doors? I haven't taken the door panels off to look and trust me, they were put in in 1996, just like the spark plugs and air filter were
Old May 28, 2025 | 09:16 PM
Does your truck have the infinity system? (it would say so on the head unit.)
Old May 29, 2025 | 06:53 AM
2pfspiff's Avatar
2pfspiff
If it is not the infinity system then you have 6x9's. Can fit 6-1/2" speakers with a kit. Order from Crutchfield. The will give you the wire adapters and speaker plate as part of the purchase for free. I replaced mine in January on my 96. If you want to replace the rears, they are 6-1/2".
Old May 29, 2025 | 07:40 AM
Moparite's Avatar
Moparite
You have to watch the depth of the speaker, If you go to deep the window will hit it when you lower it. I had to make a spacer and cut the door panel out for my Pioneer's(6x9) to fit. And it's always a good idea to use
these these
to keep the rain/moisture off them.
Old May 29, 2025 | 08:51 AM
Originally Posted by Moparite
You have to watch the depth of the speaker, If you go to deep the window will hit it when you lower it. I had to make a spacer and cut the door panel out for my Pioneer's(6x9) to fit. And it's always a good idea to use these to keep the rain/moisture off them.
I don't think putting Bailey the dog on your door would help.
Link doesn't work for me.
Old May 29, 2025 | 12:57 PM
2pfspiff's Avatar
2pfspiff
Same here with the link.
Old May 30, 2025 | 08:07 AM
Moparite's Avatar
Moparite
Let's try again, Copy and pate the link. "hyyp://www.amazon.com/XTC-x9-Foam-Baffle-Pair/dp/B0002ZPNY6"
They are called XTC speaker baffles and you can get them from a bunch of places. They also come in lot's of different sizes.
Old May 30, 2025 | 05:18 PM
Wolfen1086's Avatar
Wolfen1086
A what? I removed a stock am/FM cassette radio and installed a duel 65 watt radio
when I measured them I removed the door panel and saw not the back of the speakers but the front I measured top to bottom and got 9" side to side I got 6 1/2"
Been there done that, spent 4 hours cutting through teh doors inside cover dunk so I wouldn't screw it up and put them on the outside of eh inside door panel
LMAO
Thanks I'll try that
Old May 31, 2025 | 02:52 PM
Wolfen1086's Avatar
Wolfen1086
hyyp doesn't work
Old May 31, 2025 | 08:15 PM
Moparite's Avatar
Moparite
It's " https:// " Or google search ( XTC speaker baffles 6X9 ) it will be the first result. If I just put the address (no link) it converts it to one but doesn't work.
