1998 dodge ram 1500 5.9
Old May 31, 2025 | 02:10 PM
  #21
JohnathanG27's Avatar
JohnathanG27
That would be appreciated. Always good to see how these turn out, ESPECIALLY if it solves the issue.
Most definitely lol im hoping it works
Old May 31, 2025 | 08:45 PM
  #22
Moparite's Avatar
Moparite
Alrightyyy so update lol no power to the connector that goes on the bottom of the ignition coil .
So I put the multimeter on it and had someone try and crank the truck and i got no voltage i did it twice and got nothing coming out of it , could that crank sensor be the issue ?
Witch coil wire are you testing? One will have power from the asd relay (if working) and the other will be a ground pulse from the pcm (if sensors are good). If there is no power from the asd relay, Coil, 02's and injectors won't have any either. So crank sensor will make no difference.
Old May 31, 2025 | 08:56 PM
  #23
JohnathanG27
I was testing the one that clips on to the bottom of the ignition coil it has 2 wires on it
Old Jun 1, 2025 | 07:12 AM
  #24
Moparite's Avatar
Moparite
Witch one? I looked it up in the service manual and the one you should be checking is DG/OR dark green with an orange tracer.
Old Jun 5, 2025 | 10:09 PM
  #25
JohnathanG27
I apologize i never got the notification you sent something and ill have to get you a picture i dont quite know how to describe it , we might be talking about the same one , ima visual type of person lol
Old Jun 5, 2025 | 10:13 PM
  #26
JohnathanG27
Hey so back with another update lol ,I got the bolts replaced and tightened up the crank sensor , something was telling me to check the distributor cause my brother called himself working on it while I was at work and I took it off the rotor was messed up and he also didnt put it back on cylinder 1 after messing with it , I might have found my issue. Lol
