Running Rich
Old Jul 24, 2025 | 10:10 AM
MXram's Avatar
MXram
Default Running Rich
Howdy all,
I’ve been battling a rich condition for a long time. The engine starts prematurely when cranking (the RPMs don’t surge like normal) and idles rough. WOT is no problem with plenty of power but idle is terrible. I have an OBD-1 scan tool for my ‘95 with a 5.9 Magnum and all values are within range. Whenever I accelerate the engine sounds like it’s wheezing because the IAC valve doesn’t open enough. I did replace it with a Mopar IAC valve. New O2 sensor NTK, new catalytic converter from Magnaflow.
Any suggestions?
Old Jul 24, 2025 | 10:57 AM
IAC is only active at idle. When you crack open the throttle, IAC should close up.
Have a look at your plugs. See what they look like. If it's just a couple cylinders running rich, it's a different problem from ALL of them running rich.
Old Jul 24, 2025 | 12:12 PM
MXram's Avatar
MXram
Thanks so much for the quick reply. I will have to pull the plugs and report back.
