Towing issues
Old Aug 17, 2025 | 09:46 PM
sdkauota's Avatar
sdkauota
Yeah. 7 doesn't seem too far off the mark. If it hasn't happened lately, plugs, wires, cap, rotor, and O2 sensors (copper plugs, brass terminal on the cap, and NTK or Denso sensors.....) Might help some. (reset PCM after changing everything.)
Have replaced all those components but if 7 to 8 mpg sounds about normal for this truck then it is what it is.
Old Aug 17, 2025 | 10:01 PM
DerTruck's Avatar
DerTruck
Originally Posted by sdkauota
So when you say left and right is that sitting in the truck of looking from in front of the truck? I'm attaching a picture.
Yes looking at it from the front. The lines are hooked up correctly and the check valve is already removed.
Old Aug 19, 2025 | 10:24 AM
sdkauota's Avatar
sdkauota
Tire size is 245/ 75R 16 as for the gear ratio one spin of the tire turns the driveshaft just under 2 times? like 1.8? doesn't sound right. I think it's a limited slip and maybe that has something to do with it not giving me the right ratio? Is there another way to tell without taking the rear axle cover off?
Old Aug 19, 2025 | 10:33 AM
If you spin one tire, does the other side spin the same way? Or does it go the opposite direction?
Probably 3.55 gears.... those were pretty common.
Old Aug 19, 2025 | 10:45 AM
AtomicDog's Avatar
AtomicDog
There may be a metal tag on one of the bolts on the rear differential cover that has the gear ratio printed on it. It sounds like you've maintained stock sized tires and haven't installed taller tires on your truck, so your current gearing shouldn't be a factor unless you have gearing less than 3.55.
Old Aug 19, 2025 | 02:58 PM
sdkauota's Avatar
sdkauota
Found the tag on the axle it's is a 3.55. So you all think the truck won't have a problem pulling a 5,000 pound trailer up long steep hills?
Old Aug 19, 2025 | 04:39 PM
Stay out of O/D while towing.
Old Aug 19, 2025 | 05:02 PM
sdkauota's Avatar
sdkauota
Will do!!! Thank you.
