Wheelbase/ Thrust angle
Old Aug 23, 2025 | 12:57 PM
RamST's Avatar
RamST
Default Wheelbase/ Thrust angle
Hey guys, about a year or so ago I had put new HD leaf springs on my 97 dodge ram 1500 4x4 club cab. Found out after an alignment that my thrust angle was out about 3/8”. So I just installed an alignment plate from Specialty products and adjusted it. Measured from center of hub front to center of hub rear and it was about 1/2” off towards the passenger side so I figured ok I adjusted it too much. ( this was also done in my very not level driveway). Leaf springs started creeking while driving so it keep reminding me “ yea I need to readjust that”. Got it on flat level ground now and figured before I do anything I’m going to remeasure. So knowing the wheelbase for this truck is 139”, remeasured and I’m getting 139 1/2” on both sides. My question is after all the research I did and everything saying a half inch is still acceptable for spec. Would any of you guys stress over it being a half inch closer over it being exactly spot on 139”? Let me know. Also truck drives straight and no tilted steering wheel.
Old Aug 23, 2025 | 01:41 PM
If it drives good, doesn't wear the tires in an odd fashion, that's all you care about.
Old Aug 23, 2025 | 01:59 PM
RamST's Avatar
RamST
Gotcha, thanks
