Random no power,sluggish,with evap code
Old Nov 21, 2025 | 09:38 PM
DMan1972's Avatar
DMan1972
Default Random no power,sluggish,with evap code
01 Dodge pickup . Had large and small evap leak codes. Found that two hoses were off evap canisters and one joining canisters was split. Fixed hoses and reset codes. Ran good for awhile. Now just one evap code and no power and cuts out or stalls and some popping or sputtering,if I am moving down the road and I turn key off and back on the truck picks up brief power and then loses it again . I have to repeat off and on to accelerate to higher speeds. Hills are almost impossible. If I let it sit a minute and start in 1st gear ,it may climb hill. Still only showing 1 code for evap leak. It seems to me that with it responding a little better with the off and back on with key ,that it may be a sensor issue. Ty for any type of help or suggestions. Occasionally it may run with no problem and then get in it and it is horrible again. I am not familiar with forum and how to find this post or reply .if possible please text reply here to help others and to me at 5806600087 thank you
Old Nov 22, 2025 | 12:12 PM
AtomicDog's Avatar
AtomicDog
Has a tune-up/maintenance been done to the engine (spark plugs, plug wires, distributor cap and rotor) anytime in the recent past? Lastly, what's the evap code you're getting?
Old Nov 22, 2025 | 01:55 PM
Moparite's Avatar
Moparite
There is an elbow coming off the throttle body (front left looking at it from the front) that cracks. This is where the HVAC system get it's vac from so have a look at it. If the leak is large enough it can cause running issues.
You post a question like you did and revisit the site in a day or so and you will get responses. No calls, Texts or emails. You may get a email from the forum to the email address you sighed up with notifying you that you have a reply.
