4wd noise
Old Dec 14, 2025 | 01:35 AM
Mneukirch86's Avatar
Mneukirch86
Default 4wd noise
So today we had our first snow storm. Of the season and I went to put my truck in four-wheel high only to end up with excessive gear whine and clicking.
And I’m not sure what the issue is
My truck has new front u joint axles as well as new fluid in differentials and transfer case
I’m not really sure what’s going on with this noise any thoughts?
2001 Dodge ram 1500 5.9 gas 4wd
Old Dec 14, 2025 | 02:47 AM
DerTruck's Avatar
DerTruck
Did you ever have the 4 wheel drive working without issues in the past ? Can you clarify what "CB joint axles" means ? AFAIK there are no CV axle shafts for this application, only u-joint.
Old Dec 14, 2025 | 07:06 AM
Mneukirch86
Spelling error ..
yes I did have it working without issues in the past
Old Dec 16, 2025 | 09:42 AM
Keith_L's Avatar
Keith_L
You're gonna have to run through the standard troubleshooting. Is the t-case truly going into 4hi (does the front d/s freewheel in 2hi and lock up in 4hi?) Is there vacuum at the CAD? If yes, is the CAD moving the fork?
Old Dec 16, 2025 | 11:41 AM
dodgetruck2's Avatar
dodgetruck2
Yes, I would start with verifying the CAD functions, not sure how bad the wine is but could it be a vacuum leak at the transfer case block?
