air & heated mirror buttons flashing
Old Dec 19, 2025 | 02:56 PM
harleymandan@hotmail.com's Avatar
Default air & heated mirror buttons flashing
brought my 2002 dodge ram 1500 too mechanic for thermostat replacement no heat.he change blend door actuator.still no heat and now my air condition light and heated mirror light are flashing
brought it back to this guy said he cant figure it out or no code..need help please.maybe another blend door or what
Old Dec 21, 2025 | 09:41 AM
Keith_L's Avatar
Keith_L
So '02 1500 is Gen 3 and you're in the wrong forum.
The flashing light means the HVAC module or system has detected a problem. There should be a code but you'll need an upper end scan tool to get there. You need something that will specifically allow you to access each subsystem, not just "pull codes" in general. I use an Otofix D1 Pro (Autel) but any brand can do it, eg Topdon, Foxwell, Xtool et al
