1984-1997 Dodge Ram 1500 Parts Discontinued
Old Jan 6, 2026 | 02:27 PM
Circle Star Ranch's Avatar
Circle Star Ranch
Default 1984-1997 Dodge Ram 1500 Parts Discontinued
I am hoping that someone can locate the motor mount bolts to the block. 1984-1997 Mopar 9416171 is the Dodge Ram OEM part number. If you can post what bolts are identical for replacement, that would be great. I may need to order 4 or 5 sets for the future.
Old Jan 6, 2026 | 05:50 PM
If you have even one, go to your local hardware store, and match 'em up. That number is still available thru chrysler marine.... (though most list it as out of stock.) I can't find specs for the bolt.
Old Jan 6, 2026 | 11:26 PM
AtomicDog's Avatar
AtomicDog
Post
According to what I've been able to find Mopar part 9416 171 equates to a Bolt, 3/8-16 x 1.25". It is used in numerous applications. Those bolts should be readily available in any hardware store. I'd also pickup flat washers to go with each bolt. Not sure if it's grade 5 or 8, but I'd go with grade 8.
Old Jan 10, 2026 | 09:56 AM
Keith_L's Avatar
Keith_L
Hmm would be interesting to know hex size. On the motor mounts for a '95 ZJ with 318 they pulled a real dick move and used an 11/16" head (yes, I'm sure, and not metnic).
