CTM Issues
Old Feb 8, 2026 | 01:54 PM
CDMino's Avatar
CDMino
Default CTM Issues
Hello all, I have a 2001 Dodge Dakota 5.9L with about 180,000 miles, and I’m having issues with my headlights, wipers, and horn. I’ve been told the problem is likely the central timing module (CTM). I know where the module is located and I have the part number from my current unit (P56045452AK). My question is: does the replacement module need to have the exact same number, or can I use a cheaper alternative with a different part number? The exact-matching part I found is nearly $300, while others with different numbers are considerably less expensive. Any help or guidance you can provide would be greatly appreciated. Thanks!
Old Feb 8, 2026 | 03:08 PM
There are two different versions of the CTM, standard, and high-line. I am guessing you probably have the high-line, thus, more expensive.
