Over Charging damage?
Old Feb 9, 2026 | 10:02 PM
Do you get fuel pump prime at initial key on? Are you getting spark? Injector pulse?
Old Feb 9, 2026 | 11:56 PM
Jerrey1972's Avatar
Jerrey1972
Yes the pump is priming but no movement on the TAC to indicate I have anything from the crank position sensor. I know with out the crank position you get no spark as I recall. So the question is after replacing the crank sensor is there anything I'm missing here or do I need to look at replacing my ECM.
Old Feb 10, 2026 | 02:16 AM
AtomicDog's Avatar
AtomicDog
Did you purchase a high quality crank sensor, like a Delphi? Crank sensors for these engines are very sensitive to having high quality crank sensors...
Old Feb 10, 2026 | 09:15 AM
Jerrey1972's Avatar
Jerrey1972
I replaced it with what I had available quick its the same autozone part that was in the truck for the last 40k miles.
Old Feb 10, 2026 | 09:30 AM
ARE you getting spark?
