1999 2500 Gear Shift (column) problem
Old Feb 22, 2026 | 08:48 AM
Dave 39's Avatar
Dave 39
Default 1999 2500 Gear Shift (column) problem
My Ram has probably more than typical rust. 2 years ago my column gear shifter started flopping all over the place. I found a mechanic that was able to tack weld the gear shift control to the frame where it had been attached to a rusted bracket. Now it has broken loose again and I'm wondering if there is an after-market bracket that can be welded to the lower frame to reattach it? Has anyone found a permanent fix for this? Can't use the truck at this point and I really need the use of the plow.
Dave
Old Feb 22, 2026 | 09:13 AM
Gonna have to fab something up. So far as I know, that isn't a common replacement part.
