Rich Fuel Condition (Stumped)
Old Mar 14, 2026 | 04:32 PM
Bigborealaska's Avatar
Bigborealaska
Default Rich Fuel Condition (Stumped)
I have a 95 5.9L that has edelbrock fuel heads a hot cam and some work done to it. I have replaced every sensor on the vehicle to include the engine coolant temp. It also has a true duel exhaust from the headers to the tailpipes It blows a black mist just on the driver's side. The plugs, wires, rotor, coil everything is new. I know it's raw fuel but I dont know what is causing it and it's just the driver side.
I've run the truck without the air filter assembly for a week or so as well to see if a cold air would benefit me and it will, however this has occurred since I built the motor from day 1. It has the stock fuel injectors still and that was my last go to but with cost I didn't want to replace them without knowing that's the issue. Any help is appreciated.
Old Mar 14, 2026 | 08:34 PM
DerTruck's Avatar
DerTruck
Is the truck still running the factory PCM ? 95 is pre-obd2 so you might no have scan tool for it but I'd look at O2 readings and fuel trims. It could be a leaking injector but as you said it's an expensive gamble.
Old Mar 14, 2026 | 08:57 PM
Bigborealaska
It is the factory pcm. I wish I could find one of dodges high-performance pcms they made back in the day. It's even harder for my truck because it's a 5 speed so no go for that.
I will upgrade the wiring harness and pcm to an 96 or 97 and get a tune so it will meet the potential of the motor. Need to wait until it warms up here in Idaho before I tackle that. Right now alot is being left on the table with my build due to obd1. I have 0 codes at least key cycle wise as I dont have a scanner. I wish I did it's so easy to read fuel trims and everything on obdII with my other scanner but this one just isn't that easy.
My o2 sensor Is new and I had a bung made for it for my x pipe to make it a true duel exhaust. Couldn't put it anywhere else to get a reading from both banks. Not sure if that's caused an issue or not.
Old Mar 15, 2026 | 01:46 AM
DerTruck's Avatar
DerTruck
Hmm the truck should have had two O2 sensors from the factory. What did you do with the other one ?
Old Mar 15, 2026 | 09:28 AM
On a 95?
Wasn't it just the 'heavy duty' version that had two?
With all the internal changes to the engine, the stock PCM isn't going to have a clue. As for blowing raw fuel out the exhaust...... Cylinder misfire? Injector stuck open?
Old Mar 15, 2026 | 10:47 AM
Bigborealaska
It just had 1 o2 sensor from the factory. And it's not misfiring at all she runs amazing. I'm wondering if it just needs new injectors and a swap to a 96 harness and pcm and then a tune to sort it all out.
Old Mar 15, 2026 | 10:57 AM
Put fuel pressure gauge on it, cycle the key a couple times to build pressure, then let it sit, see how quickly pressure bleeds off.
Old Mar 15, 2026 | 12:50 PM
DerTruck's Avatar
DerTruck
On a 95?
My bad, you're right the light duty only has one O2 sensor. Which makes it even more puzzling because the banks are not metered/controlled separately. Still would be good to know what the sensor is reading.
