Transmission won’t shift into 3rd under acceleration
Subscribe
Apr 17, 2026 | 03:17 PM
Quote: Two sensors.... That's what the one wire sensor is seeing. Need to plug in with a scanner to see what the pcm thinks engine temp is.
ohh I don’t have a scanner
Reply 0
Apr 17, 2026 | 04:07 PM
Quote: ohh I don’t have a scanner
The ones at the local parts stores "might" read live data......
Reply 0
Apr 17, 2026 | 09:20 PM
Quote: The ones at the local parts stores "might" read live data......
ohh ok I will try, I always assumed because this truck does not have an obd2 port that I would need a special scanner to scan it. I will head to the local auto parts stores to see this weekend and will report back
Reply 0
Apr 17, 2026 | 09:21 PM
Quote: ohh ok I will try, I always assumed because this truck does not have an obd2 port that I would need a special scanner to scan it. I will head to the local auto parts stores to see this weekend and will report back
Finding a parts store that still has an OBDI scanner may indeed be a problem.... Hadn't considered that......
Reply 0
Apr 18, 2026 | 01:12 AM
If you plan to keep that truck long term, you might want to see if you can find an old Snap-On MT2500 scanner and the Chrysler/Dodge cartridge that covers that year truck and the adapter that plugs into the diagnostic port. You can find them on eBay, Facebook Marketplace and Craigslist, to name a few sources...
Reply 0
Apr 18, 2026 | 12:58 PM
I know there are OBD1 to OBD2 adaptors. They allow to use an OBD2 scanner. I have never used it but, worth a shot. Just an idea.
Reply 0
Apr 20, 2026 | 10:51 AM
Quote: Finding a parts store that still has an OBDI scanner may indeed be a problem.... Hadn't considered that......
So I bought one of those obd1 to obd2 adapters and that don’t work and i can’t find an affordable obd1 scanner for Chrysler. So I told years ago that they changed the thermostat to a cooler one so I’m ordered a 180 degree and a 195 degree thermostat from rockauto and see if that makes a difference. I will keep yall informed and thank yall for your help.
Reply 0
Apr 20, 2026 | 12:57 PM
Chrysler had their very own specific plug for the scanner.... they weren't standardized yet then...... Makes life interesting. There is a selection of MT2500 scanners on ebay, just make sure it has the right cartridges/adapters.....
Reply 0
Subscribe
