No front park/marker lights
Old Apr 15, 2026 | 09:39 PM
Originally Posted by DerTruck
Put the test light clamp on battery positive and check that the black wires have proper ground connection. Possibly the turn signal finds ground going through the marker/license plate lights at the back. Sounds weird but remember, if there is a way current will find it
Do they ground at G100? On my truck, EVERY connection that went there was rusted out, and broken. (thus, no start, as the fuel pump grounds there as well....) In front of the battery WAY down on the bottom part of the fender. It's a stud that sticks straight up. a BUNCH of wires go to it, and most are soldered to a single connector.
Old Apr 15, 2026 | 09:51 PM
5.9gopher00's Avatar
5.9gopher00
yes I checked G100 by using a test light and I have ground. I’m so confused why I don’t have lights.
Old Apr 15, 2026 | 10:23 PM
DerTruck's Avatar
DerTruck
One of the challenges trying to help over the Internet is that we can't see how you are doing tests so apologies if this is a redundant question: Did you test the ground at the lightbulb sockets or down at the G100 ground point ? There are what Chrysler calls "joint connectors" between the lights and the ground point.
Old Apr 15, 2026 | 11:16 PM
5.9gopher00
yeah so I checked ground first at the G100 ground, had ground there, moved to the socket, tested for power on one side. Had power and flashing when turn signals on. Other side of the socket had ground on both ends.
Old Apr 16, 2026 | 12:10 AM
DerTruck's Avatar
DerTruck
Now I'm baffled too . Do you have the correct 3157NA incandescent light bulbs ? Running out of ideas....
Old Apr 16, 2026 | 12:23 AM
AtomicDog's Avatar
AtomicDog
Is the bulb in the socket the correct way? The bulb only fits properly one way, but it will actually go in the socket in two ways...
Old Apr 16, 2026 | 11:07 AM
5.9gopher00
yep 3157Na bulbs
Old Apr 16, 2026 | 01:06 PM
DerTruck's Avatar
DerTruck
It occurred to me that if there is a phantom ground that makes the tun signal work it would also fool your test light. Try rigging up a temporary ground at the three pin connector, black wire to ground.
Old Apr 17, 2026 | 10:55 PM
5.9gopher00
not sure what the three pin connector is but I’ve got three wires going to that socket. A wire for park lights, a wire to the turns and a ground wire. Is it possible to ground the black (ground) wire to try?
Old Apr 17, 2026 | 11:41 PM
DerTruck's Avatar
DerTruck
Yes that's the one. Chrysler calls it a "connector" I guess because it connects to the bulb. Note there are only three wires although the bulb has 4 pins, the two grounds are tied together in the "connector".
