O2 Simulators
Thinking about guttin' out the ol cat. If I did that, I know I'll then have to deal with the O2 sensors. From the things I've read on dodgeforum, an O2 simulator would do the trick. My question is; where can I find one? And, would this have any negative affects? I don't care about emissions or anything like that. Thanks!
I would think you would only have to have one for the rear O2 sensor wouldnt you? The front one reads before the cat. But yeah I been thinking about doing away with my cat also, and figured I would see what happened and if I ended up needing one, then I would get it.
ORIGINAL: livinginh
Casper makes the best sims. They're pricey, but they are the best as far as quality and length of life.
https://www.casperselectronics.com/M...egory_Code=Ram
