Oil Pressure Drop - Help
Old Jan 20, 2006 | 07:22 PM
kylerebbe's Avatar
kylerebbe
Default Oil Pressure Drop - Help
I have a 5.2L 96 ram. One day I was getting on the freeway and I got on it a little bit, shortly after my oil light came on and pressure droped to about 10 than to 0 within about 5 seconds. Immediately turned the truck off and pulled over. After about 5 minutes I turned the truck back on and everything seem'd to be okay. I changed the oil and still had the problem a few times afterwards. I then brought it to a mechanic and he replaced my sender unit and that didnt fix the problem. He's got it again now and thinks it may be my guage, he's hooking up a mechanical one now. I know my engine is most likely dirty due to my past overdue air intake being messed up. When I drive normally it seems that it drives just fine, I mostly only have this problem when I get on it a bit and then return to normal driving. Does anyone have any ideas?
Old Jan 20, 2006 | 07:26 PM
kylerebbe's Avatar
kylerebbe
Default RE: Oil Pressure Drop - Help
Oh yeah, and for the most part my motor sounds fine, no knocking that I can hear.
Old Jan 20, 2006 | 08:11 PM
crazy1snow's Avatar
crazy1snow
sounds to me like the serp belt might be slippin on the oil pump. maybe check that out. if it's got a lot of miles on the belt you should really check it out.
Old Jan 20, 2006 | 08:43 PM
kylerebbe's Avatar
kylerebbe
Mechanic said guage is not the problem, he is thinking my oil screen or bearings... I dont think its bearings though, my motor has no noise and the pressure runs perfect when its not messing up.
Old Jan 20, 2006 | 08:47 PM
Socha_62's Avatar
Socha_62
The pick-up could be getting clogged. That would explain when you shut it off it works again. It could get clogged, then when you shut it off theres no suction, so whatever is cloging it settles back down to the bottom of the pan.
Old Jan 24, 2006 | 01:06 AM
hemi_powered5924's Avatar
hemi_powered5924
what kind of motor oil are you using???
Old Jan 24, 2006 | 04:02 AM
ryans590's Avatar
ryans590
im shure you alredy did this wen you cnanged the oil you changet the filter too right?
