35" tires and lift kit needed
Old Jan 22, 2006 | 03:17 PM
jfantastik60's Avatar
jfantastik60
Default 35" tires and lift kit needed
hey i want to fit 35" tires on my ram but with the smallest lift kit b/c i dont want to lose any serious handling... i have a reg cab dodge ram sport 4x4 so any help needed anyone who has done this would be greatly appreciated thanks -John
Old Jan 22, 2006 | 03:21 PM
Socha_62's Avatar
Socha_62
Default RE: 35" tires and lift kit needed
To fit them with no rubbing I think its a 5" kit. But this is always an arguement around here
Old Jan 22, 2006 | 04:07 PM
Tani1500's Avatar
Tani1500
yea it all depends for some stupid reason, i have 35's and 5in and there tons off room. ive also heard that you can fit them with a 3in lift or even with no lift or just 2in spacers. it all depends on the truck and if the tires are true to size or not.
Old Jan 23, 2006 | 12:45 AM
jfantastik60
id like to get like a 3 or 4 inch lift b/c the sport model already has a 2 inch lift or something like that i heard
Old Jan 23, 2006 | 01:40 AM
Tani1500's Avatar
Tani1500
ok heres the think. the sports dont really have a lift. only the offroad package has a 2in lift and if you had the offroad package getting a 3 in lift is pointless because it wouldnt do anything unless its spacers. because if its coils, you get 3 in with a reg. ram. the offroad ram would only get 1 more inch lift.
Old Jan 23, 2006 | 02:26 AM
20dodgeram01's Avatar
20dodgeram01
regular dodge rams are kindof low.. dodge ram 4x4's have about a 2 inch lift on it.. atleast mine has blocks in the back.. making it sit higher then regular dodges.. then theres the offroad editions with another 2 inches on top of that.. i know because i got a 3 inch lift on mine and sit alittle higher then the offroads.. but anyway.. i have a 3 inch on my ram 4x4 and it says it can clear 35's easy.. 5 inch will clear 37's
Old Jan 24, 2006 | 06:04 PM
WD40's Avatar
WD40
I have the OFF ROAD package. I have 315 70 17 tires on my truck, with no lift. There is very little rubbing. The front wheel well needed a little triming. I had to take off the front bottom two inches of plastic. Note the off road comes with a 2 inch lift. I not sure but I think one more inch would have been prefect. I'm poor so I'll have to live with the little rubbing. Good luck.
Old Jan 24, 2006 | 06:58 PM
jfantastik60
hey thanks man but what size in inches does 315 come out to be and how wide are they
Old Jan 24, 2006 | 07:18 PM
20dodgeram01
315's are very close to 35 inch tires.. probally 34 1/2.. and around 12- 12 1/2 inches wide
Old Feb 8, 2006 | 07:47 AM
Chopper1's Avatar
Chopper1
I have a 97 1500 Sport. Put 33" X 12.5 Dunlops on with a 10 inch wheel which kicked them out some and rubbed in parking lot turns or slight turns with a dip/bump. Put a Rancho 3" lift which was closer to 2-1/2", and all was good.
Next set of tires are 35" M/T with an added 3" body lift. Turn the wheels hard and they miss the wheel well edges by about 1 to 1-1/2" Any more tire and a bump would probably push it on the edges of the wheel well.
5-1/2" and 35's work well.
