Light Wing
Old Jan 23, 2006 | 01:46 PM
BFG's Avatar
BFG
Default Light Wing
http://www.everythingoffroad.com/ind...emcrr.73x.html
Has anyone tried one of these Light Wings?
They bolt on where your front plate holder would go.
Thanks for the feedback.
Dave
Old Jan 23, 2006 | 01:58 PM
ryans590's Avatar
ryans590
Default RE: Light Wing
there alright its kinda tight to bolt the fight on they dont give you much room they oxidize real quick too
Old Jan 23, 2006 | 02:08 PM
BFG's Avatar
BFG
The oxidize real quick.... hmmmm
Which one did you get?
Are they not all aluminum?
Thanks.
Old Jan 23, 2006 | 05:30 PM
livinginh's Avatar
livinginh
Aluminum oxidizes and pits badly if on the ground level, look what happens to old aluminum running boards. I wonder if the black would do that as badly?
Old Jan 23, 2006 | 06:55 PM
Racinfan83's Avatar
Racinfan83
The other thing to remember about bolting aluminum to steel is that you need to put a piece of clear packing tape between the alum and the steel before bolting them together. If you don't, there is some kind of chemical reaction that occurs that causes corrosion. Learned this trick when working on a semi-trailer building line at Wabash in the late 80's
Old Jan 24, 2006 | 12:01 AM
ryans590's Avatar
ryans590
the black ones are just puouter coated aluminum
ORIGINAL: Racinfan83
the chemical reaction you are talking about is called "galvanic corrosion" and you are correct it is the reaction of aluminum and steel in the presence of O2 and salt (even just thee trace amounts in the air) just a tidbit of useless info lol. anouther was to prevent this it to put some type of clear coat on it personally i use a product called "Nylac" is is specially for alum
Old Jan 24, 2006 | 12:31 AM
Racinfan83's Avatar
Racinfan83
Thanks for backin me up! I couldn't remember what it was called, but I always remembered what happened if you didn't put something on it.
