IDLE ISSUE
Old May 15, 2007 | 07:04 PM
xyzik's Avatar
xyzik
Default RE: IDLE ISSUE
probably one cause would be no air filter mounting gasket, it's one gasket that gets misplaced a lot of times.
Old May 15, 2007 | 10:03 PM
rollerstud98's Avatar
rollerstud98
ORIGINAL: xyzik
how would this cause an idle issue?
Old May 15, 2007 | 10:14 PM
padodgeram's Avatar
padodgeram
there is a hose that comes from top of valve cover to the back of the air filter box and thats how you get the build up....
Old May 16, 2007 | 05:23 PM
xyzik's Avatar
xyzik
ORIGINAL: rollerstud98
ORIGINAL: xyzik
Maybe because air that seeps in around the hat without a gasket is not filtered air, then add oily air from PCV = gunk buildup
not the only cause but one of many that may contribute to idle problems down the road.
Old May 16, 2007 | 10:50 PM
offroadzj's Avatar
offroadzj
I had the same problem and just replaced the IAC. It was only $40, and now I know I wont have to just clean it again in a week. Also put a new filter on w/ filter gasket. Also just put a filter on teh valve cover pipe so it doesnt go into the intake anymore. Hopefully it will keep the gunk away forever!!!. lol.
