Water temp with a 180 tstat?
Old Jan 25, 2006 | 03:11 PM
Dodgeramman's Avatar
Dodgeramman
Default Water temp with a 180 tstat?
This is to all you who run a 180 tstat. I just put one in and was wondering what you temp is. I have the big ol' gauge and I am running with the needle around the 2 in 200 which I figure to be 180. It goes from one side to the other. I am just curious cuz it was always around 210.
Old Jan 25, 2006 | 05:20 PM
shott8283's Avatar
shott8283
Default RE: Water temp with a 180 tstat?
looks like its doing its job..if it dropped down that much... gotta remember the factory temp gauge isnt all that acuruate.... well atleast thats what i hear
scott whast the weather like over near you? we are getting some decent snow right now
Old Jan 25, 2006 | 05:52 PM
Silver_Dodge's Avatar
Silver_Dodge
This is were mine runs in the summer time with a 180 t-stat. When I had a 195 t-stat, my needle covered about half or more of the "2"
Now that it is winter, my needle sits even lower (about right on that next line lower).
[IMG]local://upfiles/9095/5BD7BBDEF89647D59C1A3A068A328061.jpg[/IMG]
Old Jan 25, 2006 | 06:00 PM
HankL's Avatar
HankL
On my 1995 the needle stays midway between the left mark and 200 in the center.
The OBD-I scanner shows the temperature at cruise to be 183 with the Air Conditioning
off and it goes up to 187 with the AC on.
But 1995 was the last year before things changed over to OBD-II electronics.
My truck has one sensor screwed in beside the thermostat housing for the dashboard
temperature gauge, and a second sensor screwed in that goes to the PCM computer.
If electrical connections between the sensor and the PCM computer are dirty or corroded
it will throw the reading off.
Later Ram trucks just have one coolant sensor.
Old Jan 25, 2006 | 07:51 PM
Dodgeramman
ORIGINAL: shott8283
Sucks big time!! They should have closed the schools today but its exam week. I just about lost the bus over a cliff this morning, I **** you not. I love the snow but not the slush,, buses don't go good in that stuff.
Old Jan 26, 2006 | 04:00 AM
shott8283's Avatar
shott8283
yea i had to run 4wheel down the 490 outa rochester to leroy b/c the snow was so bad.. right when you cross the moroe to genesee county line its like thres no damn plows in sight.... thas the best part bout monroe county...they take there snow and slush removale as serious as we take our rams!!!!
on the 180 tstat... when your motor is running that cool with lower degree t-stat.. doesnt that trick the pcm into thinking that the motor isnt warming up at all and keeps dumping in extra fuel during the injecter pulses to try to warm it up .. essentially ruining your MPG?
Old Jan 26, 2006 | 10:43 AM
Silver_Dodge
I still average over 15 mpg. My mileage dipped some when I installed the t-stat, but I also installed the programmer at the same time. Then over time, it has come back up to around 15-16.
I've also read the the engine will throw a code if it doesn't reach a certain temp (I think someone posted 170). I believe this to be false (or at least false in the sense that it might not be based on the reading I see in the cab on the temp needle). When it is really really cold outside here in the winter (temps around 0), there are somedays when my needle barely moves off 130 the entire drive to work. That has nothing to do with a 180 t-stat, it would do the same with a 195 t-stat.
Old Jan 26, 2006 | 02:08 PM
steve05ram360's Avatar
steve05ram360
ORIGINAL: Silver_Dodge
this is where mine sits with the 180 as well
Old Jan 26, 2006 | 04:26 PM
shott8283's Avatar
shott8283
so the milieage affect ovbiously outways performance and keeping your engine cooller then?
Old Jan 26, 2006 | 05:18 PM
steve05ram360
It will throw the code if after repeated cold startups, it does not reach the op temp. above 170. I had a 180 t-stat in that I drilled a bleed hole that was a little too big and it was enough to throw the code after a few cold startups.
