best of the best..
alright guys.. it sounds like you all know what your talking about when it comes to preformance.. i'd like to know whats the best on the market when it comes to 5.2 dodge preformance.. what would you recommend as the best headers.. heads.. exhaust.. chip.. throttle body.. intake.. gear ratios.. and so on.. please let me know when i go to upgrade my truck i only want the best of the best.. no matter how expensive i'll save up for it
I want to preface my comments on this one with the fact that I really can only speak from experience on the mods that I have actually tried. I wish I could afford to compare several brands of headers, exhaust, programmers, etc..., but due to budget, I researched and bought what I could afford, and then replaced it with another type/brand only if I found it to be crappy. That said, I also have over 3000 posts on various forums asking questions about all this stuff, and this is what I have come to learn.
The things that I have learned above all else are that:
-opinions vary,
-what works on one truck might suck on another,
-some trucks can go 300000 miles with everything stock, some break going to the mailbox,
-modding is addictive,
-opinions vary,
-part selection depends on how you use your truck (street, off-road, towing, etc...),
-part selection depends on your goals for your truck (mileage, performance, etc...),
-part selection should consider the future mods you may want to also do,
-opinions vary,
-forums can be the best place to get answers and opinions, but in the end you have to just try something to know if it is going to work good for you.
Programmers/PCM: Mopar Performance PCM, Hypertech, Superchips, avoid Jet chips
Ignition: MSD
Plugs: Autolite 3923, NGK's, Champion, avoid platinum
Wires: Taylor, Mopar Performance
Cap and Rotor: Anything brass
CAI: K&N FIPK, Ramairbox, avoid Airaid
TB: Fastman, Hughes, avoid TB spacers
Intake: Modified kegger
Injectors: stock Mopar 19lb
Heads: Mopar R/T, Mopar Magnum Performance, Edelbrock, Hughes Engines, avoid trying to port stock Magnum heads
Cam: Mopar, Comp Cams
Headers: Edelbrock, Edelbrock Tri-Y, JBA, Gibson, Mopar, avoid Pacesetter
Cats: Catco, Magnaflow
Mufflers: Flowmaster, Magnaflow, Gibson
1.7rr's: Harland Sharp, Crower
T-stat: 180 degree, 195 degree, avoid 160 degree
Gear Ratios: 3:55 to 3.92's with 31's
4:10 to 4.56 with 33's
4:56 with 35's
Gear Brands: Yukon's, Precision
Suspension: Skyjacker, Fabtech, Rancho
Shocks: Rancho 9000's
Transmissions Replacements: APS Precision, Pure Evil
Transmission cooler: Flex-a-lite, B&M
Electric Fans: Flex-a-Lite, Perma-Cool
Track bars: Thuren, DT Profab, Solid Steel
Superchargers: Procharger, Vortec
Tires: Varies depending on use, size, load, preferences, etc...
Misc Good links:
http://www.dodgeram.org/
http://www.bionicdodge.com/Download/...d%20Tricks.pdf
http://www.krcperformance.com/newcon...stpopular.html
http://www.hughesengines.com/general...es/tech_rx.asp
http://www.allpar.com/mopar/318.html
http://www.southeastperformance.com/
http://www.apsprecision.com/
http://www.ring-pinion.com
http://www.dtprofab.com/dodge.htm
http://www.thurenfabrication.com/stocktb.html
http://www.solidsteel.ca/news.htm
http://www.summitracing.com/
https://dodgeforum.com/m_340929/tm.htm
http://www.differentials.com/calc.html
http://www.1010tires.com/TireSizeCalculator.asp
http://www.ronbarthelt.com
-opinions vary,
-opinions vary,
-opinions vary,
Ignition: MSD
4:56 with 35's
Misc Good links:
thanks that was a really good list.. i've narrowed it down to a mopar preformance PCM, hypertech chip, MSD ignition, autolite 3923 plugs, brass cap and rotor, ramair box, fastman tb, modified kegger intake( what is that anyway????), mopar 19lb injectors, mopar magnum preformance heads, mopar cam, mopar headers, magnaflow cat, flowmaster muffler, 180 degree thermostat and 4.56 yukon gears.. plan on getting 35's soon.. pretty much all mopar items
ORIGINAL: 20dodgeram01
yea i have a extended cab.. i have low enough torque at low rpms as it is.. i need something that can really up the power in the lower rpms.. to me 3rd gear is a real lag gear.. 1st and 2nd are fine up till 3rd
im good up untill OD... when i shift into OD and im not doing anything above 60ish its a tank... drives like a friggen school bus..
headers... i got the edelbrock shorties with the ceramic coating..felt a GREAT difference in power performance and mpg .. but the ceramic coating lasted 4 months before rust set in
Trending Topics
those are basically the same thing with the mopar pcm you will need to run premiun gass the hypertec/superchip gives you the option as well as the option of a tow setting where as towing is not recomed with the mopar pcm
Good job Silver! I have to agree with most of your statements, though in my case its gone well beyond an addiction lol.
Regarding your narrowed list,
Im sure you just missed it but no wires mentioned, Taylors or MSD wires needed if your running an ignition box, suggest getting the blaster coil as well
There is no MP PCM available for an 01 but the 00 does work on early 01s. Dont quote me on the date but I believe if your 01 is built before June of that year you can use the 00 pcm. If someone knows please correct me
New cam, aside from springs, rods & retainers be sure to also replace the tchain with a Mopar double roller while its apart
Beerbarrel going back in modified or not, get the Hughes Plenum gasket kit and bolt kit
If your going MP 2.02 RT heads, ported is better. Either way put felpro 1008 gaskets under them with ARP head studs securing them. Ported 2.02 heads may need to bump injectors to 24lb (FMS)
Go with matched Ford Motorsports 21lb injectors they will vary by .1 ohm resistance (Mopars .2 spread) or 24s depending on head/cam specs.
Something else to think about
With more hp bigger gears and tires your tranny needs consideration.
Transgo Shift kit, synthetics and a cooler or big pan recommended. Transmission temp gauges can save a rebuild.
Bigger tires, higher levels of performance means you need better brakes. Id suggest upgraded rotors/pads, either the crossdrilled, slotted or combo of both(best/not cheap) with carbon metalic pads. SSBC, Power slots and Power Shots most popular.
Sorry if I went to far but what can I say,,,,,Im a mod junkie
