cruise control ?
Old Jan 27, 2006 | 05:50 PM
mikeskywalker's Avatar
mikeskywalker
Default cruise control ?
i have a 97 RAM 1500 ext. cab my cruise dont work the light comes on when i push button but it wont set .........any help please ............
Old Jan 27, 2006 | 09:18 PM
Tani1500's Avatar
Tani1500
Default RE: cruise control ?
hum. im having the same problem. hasnt worked since my new clutch. is there a sensor on the trans some where. i know theres the one on the TB. I would first check to make sure the wire is connected on the TB.
Old Jan 27, 2006 | 10:17 PM
WD40's Avatar
WD40
I had a short in the wiring of the steering wheel. I suck at wiring, so a friend helped me. I also had a short to the radio in the steering wheel. I did do the work so I can help to tell you exactly where it was. The cruise not working ater a new clutch...I'm sorry. Hope someone else can help.
Old Jan 30, 2006 | 06:13 AM
thedemon01's Avatar
thedemon01
hey check the vacuum line buy the battery..mine was eaten away by battery acid going down the battery tray.I had the same problem and repaired the line and worked fine after that.
Old Jan 30, 2006 | 02:42 PM
Socha_62's Avatar
Socha_62
Could it be as simple as the cable going to the TB came off?
Old Jan 30, 2006 | 04:17 PM
Racinfan83's Avatar
Racinfan83
Found this on another forum. Maybe it will help you...
I had the same problem. It was a hole in the vacuum line that runs from the manifold under the air filter to the cruise control module thats under the battery. Battery corrosion crud had gotten onto the line causing a hole. Ordered a new line from the dealer for about $5. The dealer also showed me the above mentioned vacuum canister to add but I passed on it. After replacing the line all is well.
Does your cruise control fully operate? Mine would indicate on the dash that it was on but would not control speed until I replaced the line. Now my AC/Defroster vents no longer flip under acceleration
