gutting the cat
Old Jan 28, 2006 | 07:12 PM
mossy765's Avatar
mossy765
Default gutting the cat
hey guys what is the best way to gut the cat on my truck
Old Jan 28, 2006 | 07:13 PM
Socha_62's Avatar
Socha_62
Default RE: gutting the cat
Buy a high flow
Old Jan 29, 2006 | 01:08 PM
1996ramkid's Avatar
1996ramkid
i cut one of the inlet pipes off and marked it then i stuck a crow bar in the hole and beat what was left of the honny comb into small enough pices that i could shake them out and then i welded the pipe back on where i marked it then smoothed the weld and if you look right now you cant tell it's been touched.
Old Jan 29, 2006 | 01:47 PM
bansheenut's Avatar
bansheenut
im also thinking about doing this and i was told you can just take off the cat back... and then get a pointed bar and hammer out the cat.... and hten turn on the truck and rev it a little to get the honey comb type deal out... after a little of that just bolt back up
Old Jan 29, 2006 | 01:50 PM
Black97Sport's Avatar
Black97Sport
ORIGINAL: bansheenut
Pretty much how you do it...right now mine is rattling pretty bad, and I plan on doing this today, if I can get my catback loose enough to pull aside to punch the cat out
Old Jan 29, 2006 | 09:50 PM
Dodgy Style's Avatar
Dodgy Style
I have had the cat on my 1999 360 gutted and I did not like the tinny hollow sound that came from it, so I got it removed and the O2 sensors put back on and now it runs and sounds alot better. I have had it out for about 6000 kms and it still runs fine and the check engine light never came on
Old Jan 29, 2006 | 10:40 PM
bansheenut's Avatar
bansheenut
by gutting the cat/ romoving the cat.. will you notice a drop in fuel millage... like get less mpg.... or is that only if you take the sensor out.... also if you take the cat off and replace it with a 2 1/2' tubing how do you put the censor back in.... and if you dont will that make a diffence in anything
Old Jan 29, 2006 | 11:23 PM
shott8283's Avatar
shott8283
youll have to sim the 02... not exactly legal in most states ... especially emission sensative states like cali and ny... where vehicle inspection is like brain surgery
Old Jan 30, 2006 | 12:16 AM
Socha_62's Avatar
Socha_62
Glad I live in Michigan and they don't really give a crap what you do Do are suppose to have a cat though, but there are no inspections ever.
Old Jan 31, 2006 | 12:53 AM
BIGSEXY's Avatar
BIGSEXY
Gutted mine in my 97 and regreted it ,lost all low end power.
