Tranny shifter vibration???
RE: Tranny shifter vibration???
Have you checked your u-joints? Could be a loose one. Check your driveshaft for a clean spot where a balancing weight might have come off. Check the tranny mounting bolts and make sure they haven't come loose. You could even have a wheel out of balance which could shake the shifter, but not the truck cab as much. Good luck....
Thanks dude. Yeah I checked all that because I am a diesel mechanic. I work on big trucks and I dont know as much about smaller vehicles but I can usually get through. The only thing I havent checked is tire balance. I know it is a lil out of line and the ball joints are gonna need replacing before too long so maybe after I do that stuff it will fix it. Thank alot.
i have a 95 318 gasoline 5spd 4x4. my shifter shakes like a son of a bitch, but the engine idles smooth and it shifts right every time. i guess it never really bothered me, as most standard trans vehicles ive ever had have had shaky shifters. id say if everything works right and is still tight, it isnt really a problem. i know that cummins does put out a hell of a rumble...
