INCH POUNDS TO FOOT POUNDS
RE: INCH POUNDS TO FOOT POUNDS
12inch pounds is about 1 ft pound the correct method for doing the bands is as follows front adjustment band, back off lock nut 3-5 turns tighten band screw to 72 inch pounds prox 6ft pounds then back of band adjusting screw 3 5/8 turns keeping screw in same position tighten the lock nut to 30 ft pounds, rear is same as above but back screw out 4 turns then tighten rear nut to 25 ft pounds-----Hope that helps
Hey go this website. I found these one day and made myself a few copies. http://www.boltscience.com/pages/convert.htm
I hope this helps you.
