Torque
Old Feb 4, 2006 | 09:32 PM
chas3366's Avatar
chas3366
Default Torque
First, thanks to all who have posted here. This is a good site w/ alot of good information.
I have a 2000 1500 4x4 QC 360 cid 46re tranny 3.55 gears 265/75/16 Michelin M/S tires. It's only got 45k miles on it. I have installed a K&N cold air intake, cat back exhaust system w/ Magnaflow high flow cat, Superchips, MSD coil and wires, Autolite plugs (one step cooler than stock), aluminum belly pan w/ Felpro gasket, 180* thermostat, and a Transgo shift kit (adjusted bands while I was in there).
Top end is great, but this thing launches like a pig. It is plenty loud, and sounds like it should be moving, but, until I get going about 20mph, it just won't pull. I know these trucks are heavy, but it seems like w/ all that motor it should go. My wife drives a 4.7l Durango that will flat *** light 'em up, and all I have done to that is drop a K&N filter in it. Before this truck, I had a 4.7l Dakota that was even faster.
Don't get me wrong. I don't go to the strip or drive around town looking for people race, but, for all the duckies I'm pouring into this 5.9l, it would be nice to stomp it and go every once and a while. Break a wheel loose? Maybe if I dumped a bucket of 10w40 on the road under the tires.
Any suggestions on where to go from here would be appreciated.
Old Feb 4, 2006 | 09:37 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
Default RE: Torque
From what you wrote, the first thing I would look at are your gears. You might want to consider going to something like a 4.10 ratio. The other thing I would suggest is to take a look at the computer and see if it has been given the death flash. That could also account for the slowness of your truck. I am running 4.10 in the rear and have a hypertech to conteract my death flash and I can roast the tires. Prior to the hypertech I could not even break them loose.
Old Feb 4, 2006 | 09:41 PM
Racinfan83's Avatar
Racinfan83
Default RE: Torque
I'm thinking the quart of oil under the tires? My list of mods is in my sig below. I have the 3.55 gears with the 5.2, and even with the mods it won't light the tires from a dead stop. Guess that saves me money on rubber......Nice list of mods you have - may I suggest one more: a Fastman TB www.thefastman.com Around $225 if you mention DF. You would need the 52mm TB for your 360.
ORT, he has a Superchips listed, I guess you missed it....that should get rid of the death flash. I still can't light em up even with the Hypertech. Maybe it's the 500 pounds of tools and chains and crap in my tool box.......Hee,Hee,Hee
BTW, Thanks for the Hypertech info you gave me on the other post...Got mine 4 days ago - it made a big difference!
Old Feb 4, 2006 | 09:47 PM
Off_Road_Teacher
Default RE: Torque
Just got in, must not have read all that carefully. That is why I teach math. Anyway, the throttle body is a good suggestion. I know I saw a big gain when I put mine on.
Old Feb 4, 2006 | 09:57 PM
chas3366's Avatar
chas3366
Default RE: Torque
I have a set of Harland Sharp 1.7 roller rockers on the way as soon as there in the TB is next. Was the performance gain from the Fastman TB noticeable on the low end?
I have been thinking about taller gears. I have done some searches to try to figure out just how many mpg its going to cost me. 1 or 2 would be worth it, but if I'm going to go from ~15mpg to 9 or 10 that would hurt.
Old Feb 5, 2006 | 02:22 AM
97DodgeRam's Avatar
97DodgeRam
Default RE: Torque
The fastman 52mm wont hurt your mileage any. It might even help it. With my old truck I gained 2 mpg w/ a K&N FIPK and a 50mm throttlebody. I had the 318. With the 360 go w/ a 52mm
