gears?
The program can NOT replace real world experience... and the real world disagrees with your program...
that program looks like it would be great in a perfect world BUT it does NOT take into consideration aero dynamics and the additional load
the wind resistance adds. For this reason its just the opposite. Even though the 3.55's and 3.92's get a passing grade they also LACK the mechanical advantage to overcome that additional load at speed. I have seen 3-4MPG average INCREAS from going from 3.55 to 4.56 gears. I only gained 300 RPMS...
Hank does that program use the transmission ratios as well? or just rear gearing... Im starting to think that DC used that program to INCORRECTLY choose the best gear for these trucks.
SPEED SAFE, AIR RAM
SPEED SAFE, AIR RAM
ORIGINAL: muddy_blue_dodge
so are 3.55s with 33 hurting my gas mileage? or is that ok
In my 3rd Gen Ram I have a .75 overdrive and 4.56 gears
Trans gear x rear gear = OVERALL GEAR RATIO
.75 x 4.56= 3.42
Now we need to use that OVERALL GEAR RATIO to figure out what the RPMs will be at 60MPH:
SPEED x OVERALL GEAR RATIO x 336 / TIRE HIGHT = RPM
60MPH x 3.42 x 336 / 30" = 2,298RPMs I get 19-20MPG with this combo
With my 20's which are 32.5" tall:
60MPH x 3.42 x 336 / 32.5 = 2,121RPM's I get 18-19MPG with this COMBO
NOW the intresting part is... although my RPMs are lower with the 32" tall tires I get better fuel economey with the 17's which have higher RPMs at 60MPH....
So like I have posted time in and time out... RPMs are not the ONLY factor in fuel ecoomey and the load on the vehicle at any speed has a great effect on fuel economey...
So do the math and let us know what you learn.
SPEED SAFE, AIR RAM
