Spark Plug Gaps
Old Feb 5, 2006 | 08:13 PM
QuadCab318's Avatar
QuadCab318
Default Spark Plug Gaps
How much do over-gapped start plugs help in hp or torque? What is the best gap for the rams?
Old Feb 5, 2006 | 10:24 PM
delvo85's Avatar
delvo85
Default RE: Spark Plug Gaps
I would just stick wit manufacture specs. Dats what I think
Old Feb 6, 2006 | 10:23 AM
HankL's Avatar
HankL
Most of the gains from the larger gap are going to be in the 1500-3500 rpm range where the factory spec ignition timing is heavily retarded so that a 9:1 compression ratio engine can run on low octane fuel.
The gain might be 5 ft-lbs on a 340-375 ft-lb of torque engine.
I believe that you can go as large as 0.060 inches of gap on a conventional plug if you are willing to resharpen the plug electrode edges every 5,000 miles.
If you don't want to resharpen so often
you can buy some of the $6 to $12
iridium tipped sparkplugs
where the alloy of the tip is much more durable.
