New member needs help (code 37)
Old Feb 5, 2006 | 09:59 PM
monkeywrench's Avatar
monkeywrench
Default New member needs help (code 37)
I got a code 37, Ram 1500 1995.My Haynes manual does not show a code 37 for my year with a gasoline engine.It does have a code 37 for the diesel engine it says its the torque converter solonid.Can anybody help me out with this.I also have an idleing problem warm or cold it just dies when I let off the gas.It doesn't do it all the time but it does it a lot, very annoying.
Monkeywrench
Old Feb 5, 2006 | 11:36 PM
ryans590's Avatar
ryans590
Default RE: New member needs help (code 37)
take a look at this site it tells you what all the codes are, what they mean and what to do about it
http://dodgeram.org/tech/gas/Trouble/pcm_fault_code.htm
be shure to look at the note at the bottem of that page since you have a 95. do you have a tow package?
here are a cupple more sites ive done quite a bit of reserch on these pcm codes i have a 98 and was trying to find out if there is any way to get codes out but there isent as far as i can tell
http://misterfixit.com/moparcod.htm
http://www.allpar.com/fix/codes.html
Old Feb 6, 2006 | 12:56 AM
monkeywrench
Thanks for the info I do have the towing package. My CEL has not came on with the code 37 I just noticed it while checking for a code that would make me have the idleing problem.
Old Feb 6, 2006 | 02:37 AM
Socha_62's Avatar
Socha_62
Those codes don't always throw the CE. Code 37 is the trans is getting to hot. So either its overheating or your temp sensor is just messed up. Also says it could be the TCC. Do you have any RPM fluctuation while driving? Like 200-300 RPM? That could be your TCC locking on unlocking.
