tire clearence
Old Feb 8, 2006 | 12:54 AM
BigRedRam's Avatar
BigRedRam
Default tire clearence
is there any way i could fit 315/75/r16 tires with just a 2 inch coil spacer?
Old Feb 8, 2006 | 02:21 AM
shott8283's Avatar
shott8283
Default RE: tire clearence
possible... 315's whats that like a hair under 35's? if so you prolly can with a bit of rubbin at lock or bumps in the right spots...wait to see what others say
Old Feb 8, 2006 | 10:32 PM
Bassman's Avatar
Bassman
Yeah thats the tires ive been wanting to run they are 34" I figure they will probably rub a bit at the stops but they would look a lot better does any one have picture of a 2" spacer and either 315/75/16 or 285/75/16 tires ?
Old Feb 9, 2006 | 12:15 AM
20dodgeram01's Avatar
20dodgeram01
2 inch will be fine.. you can fit a 315 with a 3 inch lift on the 1500's.. and 2500's sit about 2 inches higher stock (4 inches higher then 1500's with a 2 inch coil).. you'll be fine
Old Feb 9, 2006 | 12:16 AM
suicide jockey's Avatar
suicide jockey
I had the spacer and ran 305's with no rubbing ever not twisting or turning or ever, but I think the 315's will rub maybe not on the road but on the trail for sure. I put a 3' skyjacker lift on mine and the 315's will clear now. I didn't notice you had a 2500 they'll clear easy.
