Check Engine Light?
Old Feb 8, 2006 | 03:05 AM
mattyge's Avatar
mattyge
Default Check Engine Light?
Hey again,
I need some help trying to diagnose my truck problem. After driving my truck for an extended period of time 1hour+ usually in the city, the check engine light comes on. If I stop and turn the truck off and then turn it on again it stays off. I dunno if something is getting too hott and tripping a sensor, I don't want to burn anything up. Also its a 95 and i heard they didn't start using OBD till 96 so what kind of reader do i need, if one at all.
Thanks again,
Old Feb 8, 2006 | 03:10 AM
ryans590's Avatar
ryans590
Default RE: Check Engine Light?
you dont teed a code reader just follow the steps on this site it will tell you hoe to get the code then what it means and it works on 94-97 rams
http://dodgeram.org/tech/gas/Trouble/pcm_fault_code.htm
Old Feb 8, 2006 | 03:12 AM
mattyge's Avatar
mattyge
alright sweet thanks ALOT!!!
Old Feb 8, 2006 | 03:17 AM
ryans590's Avatar
ryans590
no prob. hope its nouthing too serieous. post the code wen u get it and we can go from there
Old Feb 8, 2006 | 04:06 PM
mattyge's Avatar
mattyge
ok i just did the code readings and heres what i got:
12 - Battery Disconnect (Which I did recently)
37 - Torque converter clutch solenoid CKT or Trans temp sensor too high or low
32 - EGR Solenoid circuit
55 - End message code
Any suggestions or common fixes?
Old Feb 9, 2006 | 12:46 AM
ryans590's Avatar
ryans590
well #12 if you just disconected your batt within the last 50 starts is nouthing to worry about and #55 is just telling you its done giving codes so again nouthing to worry about now as for #32 and #37 i dont know enuf to tell you fore shure on them outher pepole have more exp with that stuff but here is what id think:
#37 could be a bad senser, tranny could be getting hot (not good) or your TC solenoide could be bad
#32 i cant think of what EGR is its something to do with emmisions i think but like i sed somone will be able to help u better than i can
Old Feb 9, 2006 | 03:02 AM
mattyge's Avatar
mattyge
ok thanks, if its something with the tranny i would like to fix it soon so if anybody else has any other ideas it would greatly appriciated
