What's up with the headlights?
Old Feb 8, 2006 | 11:46 PM
ryans590's Avatar
ryans590
Default RE: What's up with the headlights?
ORIGINAL: steve00ram360
nice thing about the upgrade is all 4 bulbs are on low beam all the time, then all 4 go to hibeam when needed... it's sweet!
you shouldent have all 4 on low beam if so your blinding the pepole comming at you because you have your highbeams and low beams on that should only happen if you have a quad beam light set up then all 4 should only be on on high beam not low beam
or wate am i thinking of a chevy? do the sports still run 9004 bulbs?
Old Feb 9, 2006 | 12:41 AM
steve05ram360's Avatar
steve05ram360
the headlights are aimed where they should be and do not blind on-comming drivers at all. I know cause I tested it by having my daughter drive it while I was in another car coming at her. no problem with blindness. all 4 lights are on low beam until the high beam is switch is activated.
Old Feb 9, 2006 | 12:51 AM
ryans590's Avatar
ryans590
yah i was currious so i looked in to it more when your on low beam the hig beam is on 50% not on all the way same as the DRL's
