Check engine light. Code PO138
Old Feb 9, 2006 | 12:19 AM
UTRok's Avatar
UTRok
Default Check engine light. Code PO138
I used my Hypertech programer and it has code PO138 can anyone help or send me in the right direction I tried the search function with no luck.
Thanks for your time.
Ok I found this P0138 1/2 O2S Shorted To Voltage does this sound right?
Old Feb 9, 2006 | 12:24 AM
ryans590's Avatar
ryans590
Default RE: Check engine light. Code PO138
its "HO2S Circuit High Voltage Bank 1 Sensor 2" (change out your o2 sencers should fix it) check your cat too (and just so you know its p0(zero not oh)138)
Old Feb 9, 2006 | 12:26 AM
UTRok's Avatar
UTRok
Thank you.
Old Feb 9, 2006 | 12:34 AM
ryans590's Avatar
ryans590
no prob thats why were all here here is a good site to check out in the future too look up your codes on http://www.obdii.com/codes.asp
Old Feb 9, 2006 | 01:02 AM
Ram_Sport's Avatar
Ram_Sport
lol, complaining about an 0 and O misconception
Old Feb 9, 2006 | 01:05 AM
ryans590's Avatar
ryans590
ORIGINAL: Ram_Sport
nope im not compalining at all my typing is worse than most but if you try to look up the code with an O (oh) insted of a 0 (zero) you wont get any results just trying to help out is all
Old Feb 9, 2006 | 02:52 AM
20dodgeram01's Avatar
20dodgeram01
i had a P0455 i think.. large evap leak.. well i took it to the dealer and they said it was the gas cap.. replaced it and it was fine for about 2 days and the same code came back on.. what do you guys think it could be???
Old Feb 9, 2006 | 02:55 AM
ryans590's Avatar
ryans590
P0455 = Evaporative Emission Control System Leak Detected (gross leak/no flow) probbley a leak in a vacume line somewhere
