Hypertech?
Old Feb 10, 2006 | 01:58 AM
DGarmon's Avatar
DGarmon
Default Hypertech?
Ok, I got my Hypertech Programer about two weeks ago and tonight I desided to try it out, straight forward on the install. But I have a question, I understand most of the setting but one, what is the REV limiter, I can go up or down in sets of +100 or -100. Should I change this? What would it do if I went up or down, Hypertech web site wasn't very helpful.
Thank,
DMan
Old Feb 10, 2006 | 02:07 AM
ryans590's Avatar
ryans590
Default RE: Hypertech?
the rev limeter limets how high yout engien rpms go so set it to however many rpm you want your moter to possabley rev to id set it around 5500
Old Feb 10, 2006 | 02:57 AM
daimler_ch5's Avatar
daimler_ch5
its basically a setting to keep you from revving too high and blowing your engine up with all that new power. depending on what type of valvetrain components youre running (i.e. racing cam, performance lifters, rods, rockers, heavy springs...) you can set it higher or lower to maximize power at top end. i think with that unit the rev limiter will also help to set your shift points to maximize acceleration power, but im not really that fimiliar with Hypertech, so dont quote me on that one.
Old Feb 10, 2006 | 03:20 AM
shott8283's Avatar
shott8283
as far as i know the hypertech as no direct way of setting the shift points..only way to change the shift points in the 46re's is a mechanical shift kit... basically the pcm has nothing to do with the tranny as far as when i should should through the gears.
Old Feb 10, 2006 | 12:50 PM
DGarmon's Avatar
DGarmon
Ok thanks for the replys, Ok, so would setting it UP on the programmer would make my Top End better and setting it LOWER would make my low end better? Now if this is correct would I lose any end or bottom end if I went either way? And since it does not change the shift points in my truck does it help any?
Thanks,
DMan
Old Feb 10, 2006 | 04:00 PM
miknwv's Avatar
miknwv
Again, I apologize for bein such a noob, but....a Hypertech isn't a chip, it's a programmer, right? How much horsepower and gas mileage could I improve being reprogrammed with a Hypertech?
Old Feb 10, 2006 | 04:40 PM
shott8283's Avatar
shott8283
yea ... its a computer type of handheld device you plug into the OBDII hookup under the dash... program the computer then disconnect it...
depends of what setting your on is how much you can expect... meaning on 89 octane through 93 octane... go to the hypertech.com website and read up on how they work... good articles they have
Old Feb 10, 2006 | 06:38 PM
Racinfan83's Avatar
Racinfan83
Ok guys. Here is the dyno sheet for my truck from the Hypertech website. You will notice that the max HP was at 4250 rpm, max torque was at 3250 rpm. The maximum gains were 18 hp at 4000 rpms and 35 ft lbs of torque at only 1250 rpms. This being on the 87 octane setting which I use. This tells me that the only thing you would gain by setting the rev limiter higher is more af a chance to REALLY hop up your engine when you REBUILD it after it blows up! The numbers for the 5.9 engine were similar - more torque and hp, but the rpms were about the same. Obviously these motors are not set up for high rpm operation in this configuration.
I did read in the FAQ section on the website that the pcm tuning does affect shift points - but there is no direct way to set that, it is in the tuning already.....
Also, if you look at the dyno charts it appears there would be no reason to pay big $ for premium gas - the torque and hp gains are about the same as the 87 program....
[IMG]local://upfiles/19461/68C80586C8EF40928C6B952544F06B84.jpg[/IMG]
Old Feb 10, 2006 | 06:58 PM
DGarmon's Avatar
DGarmon
OK Racinfan, Question then, should I just leave it set to stock or make it lower.
Old Feb 10, 2006 | 07:30 PM
Matt Harwood's Avatar
Matt Harwood
ORIGINAL: DGarmon
Leave it alone. The factory pieces are rated for stock redline of 5500. Don't push it beyond that. Lowering it will only hurt performance because you won't have as wide a powerband--there's absolutely no reason to lower the rev limiter. Leave it alone.
