Total loss of power driving down highway
Old Jul 25, 2015 | 12:04 AM
  #41
Signals's Avatar
Signals
Originally Posted by scullman37
All culprits I can think of have been replaced. Fuel pump, no change. Cam sensor, no change. Crank sensor, no change. Pcm, no change. Tps sensor, no change. Plugs, wires, cap, rotor, and Catalytic converter, no change. Unplugged O2 and, no change. According to the ASE master mechanic that scanned my truck everything is working like it should other than it is running a little lean. But O2 is cycling like it should to try and compensate. I thought that maybe the ignition coil was getting hot and may not be producing a hot enough spark. The only code that sets is a random misfire when truck acts up. Mechanic seems to think that maybe a fuel injector is failing when under load.
I had a similar situation a few years ago, and went thru and changed plugs, wires, distributor cap, coil, re-routed wires according to TSB, and had a misfire code on cylinder #8, and replaced that fuel injector only, and that was the culprit.
Old Jul 25, 2015 | 05:16 PM
  #42
scullman37's Avatar
scullman37
I replaced the crank sensor again with a new warranty one and so far so good. I haven't gotten on the freeway yet but as far as driving in town at 35 mph or less, all is good. Have a friend that works for dodge and he said that the crank sensor needs to be mopar. that it won't accept a crank sensor from aftermarket. So if this one fails I will test his theory.
Old Jul 25, 2015 | 06:19 PM
  #43
Yeah, our trucks REALLY don't like aftermarket sensor in critical locations.
Old Jul 26, 2015 | 05:06 PM
  #44
scullman37's Avatar
scullman37
Ok crank sensor replacement didn't fix it. Same problem exists. No change other than problem is becoming more frequent. Starting to lean towards bad injector or injectors. The only code that sets is random misfire code. When spark plugs were changed #7, #8, #6 were all wet with fuel.
Old Jul 26, 2015 | 05:11 PM
  #45
Do you get any specific cylinder misfire codes?
Old Jul 26, 2015 | 05:43 PM
  #46
scullman37's Avatar
scullman37
I got random misfire #8, #1, #7.
Old Jul 26, 2015 | 06:06 PM
  #47
Hhhhmmmm. suspiciously, injectors at the ends of the fuel rail. Probably wouldn't hurt to take it off, tear it down, and clean it out. Would be interesting to see what you find.
Old Jul 28, 2015 | 07:47 PM
  #48
'96 Power Wagon's Avatar
'96 Power Wagon
catalytic converter brother. had the same deal. check out this video:
Old Jul 30, 2015 | 04:35 PM
  #49
scullman37's Avatar
scullman37
Pulled injector replaced 6 out of 8 and no change. Replaced crank sensor with one from the dealer and no change. Cleaned entire fuel system and throttle body, and still no change. Runs great for a short period, and then sputters and loses all power. Doesn't die. Just starts sputtering and missing.
Old Jul 30, 2015 | 04:40 PM
  #50
Does it do the same thing with the O2 sensors unplugged? (I seem to recall you tried this, and it didn't help either.....)
What you really need, is to be able to do data logging. Plug in, go for a drive, note at what elapsed time it starts to fail, drive home, look at the logs. It *should* be patently obvious at that point, what the issue is.
