Limp mode
Old Feb 18, 2006 | 05:44 AM
brute98's Avatar
brute98
Default Limp mode
I drive other Dodge/Chrysler vehicles and some have the limp mode feature for when the transmission goes bad (bad solenoid, sensors, etc). It will stay in 1st gear and not shift to avoid damaging other components. Do the automatic transmissions on 2nd gen Rams have this feature?
Old Feb 18, 2006 | 09:44 AM
ryans590's Avatar
ryans590
Default RE: Limp mode
no i dont belive it duz to this extent i mean there is some limp mode in the comp but the trannies arnt run by thr comp so they wont really be affected by it
Old Feb 18, 2006 | 12:40 PM
Batphreak's Avatar
Batphreak
Only the fully electronic transmission have the limp-in mode. It's second gear that they stay in for that. The trucks didn't get fully electronic transmission until '02 for 1500s and '03 for the bigger boys. Before the full electronic ones there was no limp-in, as an example my truck has a 47RE the only electronic control is the torque converter lock up in overdrive, the first 3 gears are still controlled by governor pressure.
Old Feb 19, 2006 | 08:11 AM
brute98's Avatar
brute98
Thanks for the responses. Less eletronics in the transmission can be a good thing.
