thermagasket - yay or nay?
Old Feb 19, 2006 | 10:34 AM
radwebster's Avatar
radwebster
Default thermagasket - yay or nay?
anyone here ever try thermagasket to repair a damaged head gasket? looks promising...but of course everything does on the seller's site. $99 and a money back guarantee vs a $1200+ new gasket install...
Old Feb 19, 2006 | 02:09 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Default RE: thermagasket - yay or nay?
ORIGINAL: radwebster
Look at it this way -- You use it and it fails. You get $99 back PLUS more to spend repairing what should have been repaired properly from the start. That's just my opinion.
Old Feb 20, 2006 | 05:11 AM
radwebster's Avatar
radwebster
i definitely figure its worth a shot. i am just looking to see if anyone used it here. i do not agree with the "fix it the right way, otherwise it will fail" crowd.
my dad used some copper block sealer in his '86 caprice to fix a cracked head back in 1992, and that thing still runs perfect, without a leak. that was 100,000 miles ago.
i used the same stuff in my '84 corvette to fix a few cooling system leaks, and it was fine up until the day i traded it, about 10,000 miles later.
hell, i even used some JB weld to cover up two 6" long cracks in the block of a 1979 corvette, that had frozen in the winter with only water in the cooling system. that held for months (driven daily) w/o a problem before i sold it.
if i was going for a full restoration i would fix it properly, but for work vehicle or just a car thats not worth dumping thousands into, these chenical sealers DO work.
Old Feb 20, 2006 | 05:32 PM
steve05ram360's Avatar
steve05ram360
what's wrong with it to begin with? My opinion... some bandaids work, some dont... better to just fix it the right way.
Old Jun 13, 2009 | 02:32 PM
blue1solara's Avatar
blue1solara
Thumbs up Great product!
After having replaced both head gaskets in my Plymouth Voyager 3.0 and still getting milkshaked oil and lots of steam from behind, I decided to try Thermagasket. I flushed the cooling system ten times to make sure all the antifreeze was gone and then followed the instructions by the letter. After only a couple of minutes after adding the Thermagasket, the cloud from behind deminished and disappeared and I was totally amazed at the effect of this remedy. The engine started running smoother and I left the Thermagasket solution within the system for the next 50 miles or so. Then I flushed the cooling system,filled it up with new coolant, drained the engine oil, put in a new oil filter and oil, and I have not had any problems from that day on.
This was a year and two months or 10000 miles ago. I have no problem recommending this solution to anyone! Great product!
Old Jun 13, 2009 | 03:30 PM
zman17's Avatar
zman17
Retired Moderator - RIP
I know Bars Leaks make's stuff that you don't have to flush the coolant. My once upon a time boss used it in his chevy 3500 diesel and it worked and is working still. That was a year ago and a lot of miles later.
Old Jun 14, 2009 | 11:49 AM
Sheriff420's Avatar
Sheriff420
well we learned a lesson today: don't buy a corvette from radwebster.
