Luke's Link?
Old Feb 22, 2006 | 12:11 AM
Cageman's Avatar
Cageman
Default RE: Luke's Link?
Not rebuilt go look at the link posted in first question. It is a link designed to replace the org. tie rod ends useing just the org. ball shaft(not sure what to call it) go's over the ends and are adjustable. If they ever loosen they can be tightened up and if you can't they will send you a new urathane spring to fix it.
Old Feb 22, 2006 | 12:14 AM
Cageman's Avatar
Cageman
Same money for just the trackbar. To fix your trackbar would only be $60. And lukes has been around awhile haven't seen anything that is bad about them.
Old Feb 22, 2006 | 12:17 AM
Tani1500's Avatar
Tani1500
yea but i think a heavier trac bar is better and i edited my post before so you can see the second i posted up is made better. ( for 5in lift) and what do tie rod ends cost. 20 bux?
Old Feb 22, 2006 | 12:35 AM
Cageman's Avatar
Cageman
There is nothing wrong with the stock trackbar other then the ends and depending on how hard you are on your truck how many tie rod ends will you go thru? This is a one time fix.
Old Feb 22, 2006 | 02:15 AM
Socha_62's Avatar
Socha_62
In that article they also said that it actually rebuilts the ends like you guys are talking about. So if it goes bad again you can just rebuild it again.
Not to steal the thread, but it looks like you have a bad *** truck Cageman, start a thread with your mods and lets see some pics!
Old Feb 22, 2006 | 01:18 PM
securtis12's Avatar
securtis12
If you can find tie rod ends for 20 let me know the best I have seen is 40 and with Lukes you do not have to ever replace again. No it is not if you have a high lift but that is a given as you should get an adjustable one to match your lift.
Old Feb 22, 2006 | 02:54 PM
Tani1500's Avatar
Tani1500
i can get them for 20 bux. you just have to know someone
