MSD part numbers for wires
Old Feb 21, 2006 | 10:15 PM
shott8283's Avatar
shott8283
Default MSD part numbers for wires
all you guys that have the 8.5mm wires on your rams...i was wondering if you can gimme the part number of the wires you got.. summit sent me 31309 and i went to get them on today and the fricken wires dont snap onto the top of the distributer like they are saposed to..they just slide off... any help would be great b/c my dead line to get this finished is coming up soon
Old Feb 22, 2006 | 05:37 PM
Racinfan83's Avatar
Racinfan83
Default RE: MSD part numbers for wires
MSD Super Conductor 8.5 mm wires........Part #32189. Worked like a charm on mine. It says under the part # on the box "94-97 Dodge Ram Pickup - 318/360" but they worked out great on my '01.
Old Feb 22, 2006 | 10:30 PM
Tani1500's Avatar
Tani1500
yea its 32189 for red and 32183 for black. also i might have missled you the other day when i said i can go almost to my hood in water. i forgot to say that my wires are also wraped and grease and the distributor is sealer. but you should have a problem when you clean your engine like last time. also i looked it up and the 31309 is for a chrysler 79 and up 318, 340, 360. im guessing maybe its an LA motor or something? that was funny too because i had the MSD master catalog right infont of me.
Old Feb 23, 2006 | 01:44 AM
shott8283's Avatar
shott8283
the guys at MSD said that the Magnum 360 (LA) and the non magnum 360 have very LITTLE diffferences... mainly the studs on the cap are smaller on the LA's and the wires are like an inch shorter...(a few more but i wasnt paying attention).. apperantly they have been getting alot of calls about this too... hopefully they will get it worked out... orderd the 32189's lastnight and should be here tomorow and i can start wraping up the motor...kinda hoped it wouldnt take this long but it did...
ALSO... got the new headers in and on today... they actually were alot easier to put on..seams like the grinded out the chanels to help getting the wrench's in there better... took alot less time it did when i did it the first time.. i got pics today so il post everything when im done..
Old Feb 23, 2006 | 02:45 AM
steve05ram360's Avatar
steve05ram360
cool! headers, new wires and I think you fixed the plenum leak to right? (it's hard to keep track of who is doing what...) you should have a nice boost in power and milage...
let us know how it runs when your done.
Old Feb 24, 2006 | 03:06 AM
shott8283's Avatar
shott8283
oh yea... headers are just replacements from the ones that were rusting... but the plenum is fixed... new wires cap rotor plugs gaped at .40 and MSD 6A box...also took off the vicous fan and went to elec and a 180deg thermo... got er running tonight and did a complete flush on it...oil and coolant to make sure i get out all the crap i might have got it in... everythhing is draining tonight and gonna refill replenish tomorow and do a few more small things to it...
oh .. i took off the valve covers to take a peak.. and come to find out.. like 6 of the studs/bolts that hold the valve cover down were loose..loose enough to take off with just my hands... kinda odd... kinda scary too..
idle smoothed out really well... wont know anymore untill tomorow when i go break everything in
Old Feb 24, 2006 | 03:10 AM
ryans590's Avatar
ryans590
wen you get it all back together you should post some pics/info on what you did to put in your eletric fans....abd everything else, hope thes headers last longer
Old Feb 24, 2006 | 01:39 PM
steve05ram360
yeah, post some feedback on them fans! I've been putting my fan upgrade off for a while now...
what plugs did you use?
Old Feb 25, 2006 | 12:27 PM
shott8283's Avatar
shott8283
got the champion truck plugs...worked great before so im stickin with them just gappin em a bit bigger for the added sparck.... im gonna take some pics today... finally got the camera fixed
Old Feb 27, 2006 | 04:17 AM
hometheaterman's Avatar
hometheaterman
I ordered the wrong set and got all of them to fit except the coil wire it was way too short. I bent the others together with a set of pliers so they would snap on tightly. They seem to work great so far although I just changed the coil wire. I called MSD and told them the length of the one I needed and they sent it to me. The first time I waited a month and no wire the second time I did get one but it took 2 weeks or so. I put it on after having the rest on for a while. They seem to work and I like them a lot although I do wish Summit would not list them for this truck.
