Leaf Spring Center Pin
Old Feb 23, 2006 | 11:34 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
Default Leaf Spring Center Pin
I put on a set of add a leafs on my truck tonight. When I was putting one side back together, the center pin stripped out. The pin is still in there and the leaf pack is fully compressed together. I also peened over the top of the pin so the nut does not come off. I can't imagine there would be any problems since I put on all new u-bolts, and I would think they take most of the stress in the rear suspension rather than the center pin. Will this be sufficient or do I need to pull it apart and put in a new center pin?
Old Feb 23, 2006 | 11:49 PM
Tani1500's Avatar
Tani1500
Default RE: Leaf Spring Center Pin
couldnt tell you but if were me i would replace it. i think if you get into any flexy situations it may become a problem.
