Knocking
Old Feb 24, 2006 | 12:18 AM
SuperCross99E's Avatar
SuperCross99E
Default Knocking
Ok I am fairly new at this site but I have a 1999 Dodge Ram lifted 5’’ lift and there is this annoying problem. There is this knocking sound almost like a tire rubbing but its not the tires and it sounds like it is coming from my front end. I’ve check all bolts, u-joints, and shocks and everything seems to be normal. It only makes the sound at real low speeds 5-15 Mph most of the time with no load on drive system. But if I do have a load on the system going about 5-15 Mph it does it when I hit bumps. Can anyone help me with this here problem, Thanks
Old Feb 24, 2006 | 02:04 AM
Socha_62's Avatar
Socha_62
Default RE: Knocking
When you hit bumps? This throwing this out there but have you checked your control arm bushings? If you have a lift though I imagine they're pretty good quality.
Old Feb 24, 2006 | 03:56 AM
SuperCross99E
Yes, the lift is Skyjacker and I had the 4 Wheel parts Company put it on.
Old Feb 24, 2006 | 04:10 AM
ryans590's Avatar
ryans590
how steep is your drive shaft angle? could be a bad u-joint in there or binding (i dont have 5 in of lift so i dont know steep it can go befor you run into problems)
Old Feb 25, 2006 | 02:18 AM
20dodgeram01's Avatar
20dodgeram01
yeah i think its just a bad angle.. when you get up over 15mph the u-joint is just spinning so quick you cant even hear or feel it anymore.
Old Feb 25, 2006 | 04:57 PM
SuperCross99E
I really appriciate the responses. Sounds like that could be the problem and I will look into it more. Thank you again!
Old Feb 25, 2006 | 05:26 PM
BigRigTruckin66's Avatar
BigRigTruckin66
Well, I didn't really get where it was comin' from. Maybe I'm just a bad reader, but you said from the fender? Or was it the motor? Is it constant at the same pace or rapid? I need to know this kinda stuff. But from the posts, I'd agree with 20dodgeram01.
-BigRig
