Fuel Pump DIY article...
is now in the DIY forum...
https://dodgeforum.com/m_402587/tm.htm
I posted this here so anyone searching for fuel pump replacement will be able to find it easily...
Steve,
You should amend that article to include spraying the strap bolts with PBlaster. Mine came off much easier when I did that. Also, there is a point where the rear wheel might need to be removed to allow easier access to the connectors.
Oh yeah, you forgot that a lot of "****", "sonuvab$#&*", GoDAMM$#*", "filthy *****", f$#CK me", may be thrown around in the process.
yeah, i sprayed mine before yanking it apart. I figured that anyone who wrenchs already knows to spray the bolts down. Also, I didnt need to yank the tire on mine so it never occured to me.
