lack of power
Old Mar 2, 2006 | 08:04 PM
steve05ram360's Avatar
steve05ram360
Default RE: lack of power
you also mentioned 20" rims... the heavier the rims, the harder it is to get them spinning, that plus your 3.55's and dual 3" out's are killing you.
get the exhaust setup for dual 2.5" max, this should bring back enough torque to get you moving better. you should use the 2.25" rule if it's a 4x4 QC or LB. those trucks are heavier than the 2x4's and need all the torque they can get.
how is the intake side setup?
Old Mar 3, 2006 | 01:08 AM
als777on's Avatar
als777on
well i do not think that i will change the exhaust because just hade it done but my truck is a 2 wheel drive did not think that i said that before and what do you mean by how is the intake side setup i have a aftermarket air cleaner changed pletem gaskit
Old Mar 3, 2006 | 02:00 AM
ryans590's Avatar
ryans590
ORIGINAL: als777on
you could try smaller tips rather than changing the whle system
Old Mar 3, 2006 | 02:30 AM
Ram1500Dodge's Avatar
Ram1500Dodge
dont mean to steal the thread, but i got the same damn problem, 97, 5.2, ext. cab, 4x4.....cant even power brake the damn thing, single inlet to dual outlet 2.5 i believe, 32x11.50x15 tires
Old Mar 3, 2006 | 02:33 AM
ryans590's Avatar
ryans590
ORIGINAL: Ram1500Dodge
what gears are you running?
Old Mar 3, 2006 | 05:28 PM
Ram1500Dodge
ORIGINAL: ryans590
i really have no idea
Old Mar 3, 2006 | 05:37 PM
MAGICDSSMAN's Avatar
MAGICDSSMAN
I had the same problem ya'll do and after seeing steves timing chain I decided to change my own and advance the timing 4 degrees. I unleashed a ton of power doing this even with the torque converter going bad I still have alot of power. My suggestion would be to change the timing chain it will cost you less than $150 to do thats including oil and antifreeze because you need to drain both and all of your gaskets and the front seal.
Old Mar 3, 2006 | 07:53 PM
mopowar's Avatar
mopowar
Wich timing chain did you use? Did it have the marks on it to advance the timing?
Did you see any downside to doing this- mpg, pinging, etc.?
Old Mar 4, 2006 | 12:07 AM
ryans590's Avatar
ryans590
ORIGINAL: ryans590
well since you dont know im asuming you havent changed them so have a 98 5.2 4x4 and stock is 3.55 gears prob what you have unles you have an offroad edtion so your tires should be ok for that tire size. is it pretty much stock? any modds? with the 5.2 you wont be spinning your tires all over the place i mean i can squak them with mine but nouthing spectaculer
Old Mar 4, 2006 | 02:04 AM
radwebster's Avatar
radwebster
same here, i can get a little squeal for a second in either direction, but thats it
