UPDATE: Please Look...Strange rattling/knocking/squeking noise from front end
Old Mar 29, 2006 | 02:37 AM
  #31
Chopper1's Avatar
Chopper1
Default RE: Strange rattling/knocking/squeking noise from front end
That TSB is a possibility. Easy to check. You can see the linkage right at the bottom, back edge of the wheelwell. If nothing else put a rag between it and the floor. Not tight enough to hang up the linkage though. That is where it gets adjusted for a body lift.
Old Mar 29, 2006 | 03:49 AM
  #32
Sehr916's Avatar
Sehr916
Ill try that thanks again!
Old Mar 30, 2006 | 01:39 AM
  #33
Sehr916's Avatar
Sehr916
Okay, after I parked at school today I noticed that the noise isn't made in park. I was sitting in my parking spot in drive and the noise was going, as soon as I put the truck in park it went away. Transmission problem? Thanks
Old Apr 2, 2006 | 04:06 PM
  #34
badram1500's Avatar
badram1500
dodge has a tsb about a squeek/moan/rattle about a joint in the firewall where the a pillar meets the dash support. It involves removing the dash and driving a chisel into the joint to open the gap between 2 pieces of metal. The tsb can be found on www.dodgeram.info. Just a thought...
Old Apr 2, 2006 | 08:14 PM
  #35
Sehr916's Avatar
Sehr916
I will check that out also, thanks!
