Running wires for an amp?
Old Mar 10, 2006 | 04:30 AM
Lanzar's Avatar
Lanzar
Default RE: Running wires for an amp?
Wow, thanks guys that was all the info I needed
I am running a Kenwood 8101-D monoblock amp (says 1000 watts but I'm guessing it's more like 600)
Old Mar 10, 2006 | 04:37 AM
ryans590's Avatar
ryans590
well if it says 1000 then id run big enuf for that just incace, better to have over kill
Old Mar 10, 2006 | 04:50 AM
habeba86's Avatar
habeba86
You would be fine with 4 gauge
Old Mar 10, 2006 | 05:10 PM
shott8283's Avatar
shott8283
agree...4 gauge is fine... chance are youll wont use all 1000 watts... in the event you do it will only be a spike and for a short period of time... have you considerd running a stiffening cap? they help out alot with the power supply drops when the bass hits a wicked low note... general rule is 1 farad for every 500 wats.. thats playin it safe.. . 1.5 farrad would do you fine.. a 2 would do you great
Old Mar 10, 2006 | 08:00 PM
Tani1500's Avatar
Tani1500
i just removed my seat and ran them under the carpet. and came through the fire wall under the dash.
Old Mar 11, 2006 | 07:49 AM
habeba86's Avatar
habeba86
ORIGINAL: shott8283
Come on now....dont tell him to get a cap[:@] Even then its 1 farad for every 1000 watts.
400 Watts RMS x 1 @ 2 ohms
200 Watts RMS x 1 @ 4 ohms
1000 Watts Maximum Output Power
That amp wont ever push 1000 watts not even for peak.
Old Mar 11, 2006 | 09:19 AM
Lanzar's Avatar
Lanzar
I am running a 1 ohm load
still not 1000 watts though
Old Mar 11, 2006 | 01:40 PM
cantloseon22s's Avatar
cantloseon22s
without a cap i was burning through 2 altenators a year on average, since i bought my cap i have not had to replace a single altenator. they are well worth the extra money.
Old Mar 11, 2006 | 05:39 PM
habeba86's Avatar
habeba86
You should have got a new alt not a cap. I mean if they work for ya cool. You should jst upgrade the rest of your your electrical first, bcuz once ur cap gets drained that just another thing for your alt to try and re-charge.
I didnt see that it was 1 ohm stable.....or are you just running it with that load
Old Mar 12, 2006 | 03:49 AM
DWILHA's Avatar
DWILHA
get a KENETIC battery for power--1600 cranking amps, no need for a capacitor, its qick discharge ancharging cells cover all the power you need for professional and shade tree stereos
