Tranny O/D
Old Mar 19, 2006 | 03:58 AM
ryans590's Avatar
ryans590
Default RE: Tranny O/D
well im at 156000kms now (96933 miles for those of you lucky enuf to not have the metric system ramed down your throught) and havent had a single tranny **** yet... kock on wood lol... i have just started manuley shutting on and off o/d i had never thought of it before and the tranny prob could be on a better service scheduel too anyways what im saying is in my opinion if its your trannys time ittl go regardless if you baby it or beat the **** out of it
Old Mar 23, 2006 | 06:58 PM
SST_Ram's Avatar
SST_Ram
I got 125,000 miles on mine, no problesm yet. Did trans. service every 30,000, knock on wood
Old Mar 23, 2006 | 08:03 PM
Ram_Sport's Avatar
Ram_Sport
who and where does this torque management get deprogramed?, i would like to remove that i think, i do notice when i put throttle down to floor, not all the way just before the detent/downshift wot position, it will gogogo then it seems like it shifts way too soon, and its like hey cmon it would be a nicer to have em a lil later..
Old Mar 23, 2006 | 08:24 PM
mopowar's Avatar
mopowar
Check out this thread:
https://dodgeforum.com/m_425388/tm.htm
By adjusting the cable in this way it will kick-down sooner and stay longer.
Old Mar 23, 2006 | 08:26 PM
Silver_Dodge's Avatar
Silver_Dodge
Hmmmm, this makes me wonder about something I have noticed ever since I have owned my truck. When I have OD off, and am approaching speeds around 45-55 mph or so, then hit the overdrive button to turn it on, it seems like RPMs jump up noticably for a few seconds, then it shifts down into overdrive bringing rpm's down again. Is this caused by this torque management, or does the overdrive really adjust the shift point slightly?
I leave OD off in town and towing, and only turn it on when I am on the highway. I do a full trans flush about every 10,000-15,000 miles (once a year in the spring time before I start towing the camper for the summer). The usable life of ATF+4 is only about 25,000 miles.
Old Mar 23, 2006 | 08:44 PM
big truck man's Avatar
big truck man
ORIGINAL: mopowar
mopowar, So after reading this artical and the other one attached to that one I'm just a bit confused. If I read it correctly if you pull the cable out it will make the tranny shift a little sooner and with more bite, if you push the cable in it will **** later and softer. Did I understand that right?[sm=alcoholic.gif]
Old Mar 23, 2006 | 09:18 PM
mopowar's Avatar
mopowar
Sliding the cable out (towards the transmission) will make it shift later with more bite. Sliding the cable in will make it shift earlier and softer.
Old Mar 24, 2006 | 09:07 AM
Ram_Sport's Avatar
Ram_Sport
oh, ok i will monkey w/ that this summer
Old Mar 24, 2006 | 01:46 PM
big truck man
mopowar Thanks I got it now. I'll have to check this out.
Old Mar 24, 2006 | 01:53 PM
Chopper1's Avatar
Chopper1
ORIGINAL: Silver_Dodge
This is the torque converter momentarily unlocking until the trans. figures out where it needs to be.
