another bad cat
Old Mar 10, 2006 | 09:48 PM
badram1500's Avatar
badram1500
Default another bad cat
Well the cat on my 01 is plugged up. Ordered a magnaflow universal. Not to bad for $67.00 should see it in a couple of days. Will post the results(milage,power) after the install. On the up side I got 121,000 miles out of the oe converter. must have gotten lucky.
Old Mar 10, 2006 | 09:50 PM
shott8283's Avatar
shott8283
Default RE: another bad cat
yea thats not bad atall! r u welding it in yourself? or clamping? takes a bit a fabbing if its not a direct fit right?
Old Mar 10, 2006 | 09:56 PM
badram1500's Avatar
badram1500
clamps suck! leaks and rattles are all you get. I will weld the sucker in there. shouldn't be that bad,just cut out the old and slip in the new and burn away.
Old Mar 10, 2006 | 10:04 PM
Two60s98's Avatar
Two60s98
Did you happen to spot the "Chrylser admits Catalytic converters bad 1996-2001" thread in the 'Top' section of this forum? Could save some money having the DC replace it on their dime. Unless you'd prefer a Hi-flow aftermarket.
Old Mar 11, 2006 | 01:08 AM
theshocker's Avatar
theshocker
Hey badram1500, where did you get your cat?
Old Mar 11, 2006 | 02:50 AM
20dodgeram01's Avatar
20dodgeram01
how can you tell if you have a bad cat?? is there certain noises.. loses.. or smells? my exhaust is kind of smelling like a$$.. i changed the plugs and wires tonight with autolite plugs and it didnt seem to bad
Old Mar 11, 2006 | 03:31 AM
tib2001's Avatar
tib2001
rotten eggs..... odor
rattles.
sucky sucky performance
Old Mar 11, 2006 | 03:57 AM
ryans590's Avatar
ryans590
from the dodge ram faq thred at the top of the 2gen page
Catalytic Converter:
The best way to test the cat is to have someone in the cab rev the motor to about 2000 or 2500 rpm's and put a temp gun on the input and output of the cat. the output should be around 50 deg hotter than the input for proper cat operation. if the temps are the same, the cat is not working, if the input temp is high and the output temp is low, you have a plugged cat and you should have it swapped out immediately.
Old Mar 11, 2006 | 12:16 PM
badram1500's Avatar
badram1500
shocker, I got my cat at CarQuest. I work there. I know your thinking that why I got it so cheap,but that is the regular over the counter price. Most CarQuest stores are also Arrow Speed equipment dealers. Arrow Speed has pretty good prices and service. As far as having Chrysler replace it. I'd rather spend the coins and get a high flow. Besides I showed the letter about the bad cats to my dealer and the service manager said that wasn't an offical chrysler recall and untill he got something from Dodge I was out of luck.
