My rear diff grenaded at 40Mph. I need help
Old Mar 11, 2006 | 02:23 AM
96BURNER13's Avatar
96BURNER13
Default My rear diff grenaded at 40Mph. I need help
I was on my way to work today and try to beat a light so I floored it then next thing I know Im hanging off my steering wheel In the middle of the street. The pinion nut fell off and the pinion fell into the rearend then punch a hole in the housing. Where can I get a HD 9.25 housing and gears. Also my driveshaft is F@#$ed So I need an aluminum one.
[IMG]local://upfiles/30461/2D0CF2B1B13E4343AC233708081000C8.jpg[/IMG]
Old Mar 11, 2006 | 10:43 AM
Socha_62's Avatar
Socha_62
Default RE: My rear diff grenaded at 40Mph. I need help
Damn, need a new housing? [&:] Your best bet is gonna be a junk yard.
Old Mar 11, 2006 | 04:49 PM
The Burning Rom's Avatar
The Burning Rom
Junkyard for a housing...or whole axle with differential.
Why do you need an aluminum driveshaft? [&:] At any rate, something like that would probably have to be custom. Ford was the only company that used aluminum shafts stock in the 90s IIRC.
Old Mar 12, 2006 | 01:12 AM
96BURNER13's Avatar
96BURNER13
Well I figure if I gotta replace it I might as well throw in something betta.
Old Mar 13, 2006 | 01:23 PM
greenmachine's Avatar
greenmachine
I have the guts if you need them I will make you a heck of a deal. 3.92 ring and pinion, limited slip w/ bearings. All genuine Mopar never installed.
