removing u-joint
Old Mar 11, 2006 | 04:52 PM
20dodgeram01's Avatar
20dodgeram01
Default removing u-joint
can anybody tell me real quick how to remove the rear u-joint?? i have never had a u-joint that came off like this.. with the clips and trying to beat it out. can anyone tell me or send me a post? thanks im trying to work on it right now lol
Old Mar 11, 2006 | 06:11 PM
20dodgeram01
Default RE: removing u-joint
anyone?? do i have to remove the entire driveshaft to do this?
Old Mar 11, 2006 | 06:37 PM
helmsa's Avatar
helmsa
You will have to remove the drive shaft to do this, but after you remove the straps over the u-joints, it just slips out of the tranny. But that is all I can tell you.
Old Mar 11, 2006 | 08:36 PM
The Burning Rom's Avatar
The Burning Rom
You take the clip off and beat it out. I've never had a U-joint that HASN'T came off like that. Sometimes they have caps, but you still have to beat them out Or if you're lucky enough, you can press them out if you have access to the right equipment.
And as stated, you have to remove the shaft to do this
Check out the service manual download in the Merry Christmas thread It's chapter 3 in the manual...Differential & Driveline
Old Mar 12, 2006 | 02:48 AM
Cally's Avatar
Cally
Yeah taking out the drive shaft is the first priority then the second and easy way to take out the U-joint is to put the shaft into a vice and have a big C clam with a hole in the one clamp and and take out your clips and then put the C clamp on it and tighten it down and the join should pop free and then you can take it out.
Old Mar 12, 2006 | 02:39 PM
purdueranger's Avatar
purdueranger
When I had to do that to my ranger I took it to a shop and he put it ontop of a vice and used a rubber mallot and the caps came off and did the same thing to put the new u-joint back on. took him about 10-15 min to do both u-joints and get the parts out of the stock room.
